Great news!!!! I was fooling around with the transmission today, and had noticed the blocker ring to the first gear was stuck to the gear, i pried it off with a flat tip screw driver and the transmission works perfectly!!!
All except for 2nd gear, I inspected the teeth on it more and realized that the gear really needs to be replaced, because when i put it in second, it grips for a second the gives, so I need to tear the transmission back down and replace 2nd
Only problem is removing my bearings, is there anywhere that has a cheap bearing puller? or is there a way we can make a home made one? were pretty good at fabricating.
