Fox Rear End Upgrade Question
spyne
78
Fairfax, VA
I've been looking at replacing the rear upper and lower trailing arms in my car with Hotchkis components. I have a 91 LX 5.0 convertible and don't plan on sending more than about 300 HP to the rear wheels when I'm finished with the mods I have planned.
My question is this, are the Hotchkis parts worth the cost given the way I'm going to use the car or should I just go with OEM style components?
  • Sponsors(?)
RYC CUKR
1,436
Orlando
Visit site
Anything is better then the stock or OEM control arms. Personally I like Maximum Motorsports I got a set of MM LCAs at a bargain price on ebay. One thing to do though if you are gonna race it or beat on it at all it to put in some torque box reinforcements or at least have the torque boxes welded up. If you do a search there was a thread that showed exactly which seams needed to be welded.
Thread starter Similar threads Forum Replies Date
5 Rear end gear noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
C For Sale Moser 8.8 Rearend Drivetrain Parts 0
C For Sale Moser 8.8 Complete Rear End Drivetrain Parts 0
S Drivetrain 1983 mustang rear end swap Fox 5.0 Mustang Tech 2
B 90 Lsc Rearend In A 89 Fox Lx 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
MeanMussy SOLD Fs: Steeda Suspension, 8.8 Rear End, Cold Air Intake, Fox Brake Parts Suspension Parts 4
citmov Requesting pics of SN95 rear end w/tires on Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
K Fox Body - Cougar Rear End Fox 5.0 Mustang Tech 1
D Fox Rear-end brake bracket help needed Fox 5.0 Mustang Tech 3
mac16 Got rear ended in my fox, doing a swap need feedback and advice! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
9 fox rear end 1994 - 1995 Specific Tech 3
1993SSP fox body 5 lug SN95 rear end users, what wheels did you go with? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
B Mark VII rear end same as the fox? Fox 5.0 Mustang Tech 4
P Cobra brakes using fox rear end on sn95 1994 - 1995 Specific Tech 4
1993SSP 5 lug conversion fox body with 95 rear end, 17x9 too wide? Fox 5.0 Mustang Tech 6
codemonkey Fox body loses entire rear end racing Regional Forums and Event Information 10
Numbles SN95 Rear End fit in fox? Fox 5.0 Mustang Tech 78
astronut1885 Turbo Coupe rear end in a Fox? Educate me. Fox 5.0 Mustang Tech 9
1993SSP SN95 Rear end bolt up on fox body??? Fox 5.0 Mustang Tech 16
5 Rear Disc Conversion Fox 5.0 Mustang Tech 4
C Brakes Stock fox front brakes with sn95 rear Fox 5.0 Mustang Tech 8
Red50Fox Fox rear brake backing plate bolts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
Waz900 Fox rear coil-over vs. traditional spring opinions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Hollywood_Vae Wheels-Tires Rear Tires rubbing 1994 - 1995 Specific Tech 4
G Brakes Fox front spindles, what rear disc kits available? Fox 5.0 Mustang Tech 7
fredfifty Fox Coupe Rear Quarter Window Decals 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
D Superchatged Fox and rear gear info. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
Hudson N Fox Rear drum problems 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
G Convertible Rear Water Window 87-93 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
billison S197 05+ seats in a fox REARS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
T What Rear Seats Will Fit A Fox? S197, Newedge? Fox 5.0 Mustang Tech 6
sen2two Sn95 Rear Brake Lines To Fox Stock Lines 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
I Lmr Rear Disc 4-lug For Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
J Fox Mustang Convertible - Can You Reupholster Rear Interior Panels? Fox 5.0 Mustang Tech 0
ultrado Broken Lug Stud On Rear Wheel 90 Fox Help!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
9 Brakes Sti Brembo On A Fox Fox 5.0 Mustang Tech 2
86mustanglx Brakes Sn95 Axles In Fox Rear Fox 5.0 Mustang Tech 4
FoxBodyFlorio 98 Cobra Rear Into 91 Fox Fox 5.0 Mustang Tech 3
J Expired Fox Body 1986-1993 8.8" Rear Axle Assembly 3.55 Gears - $190 Drivetrain Parts 1
J Expired Fox Body 1986-1993 8.8" Rear Axle Assembly 3.55 Gears - $190 Drivetrain Parts 0
69shocktower Fox 2004 Cobra Terminator Rear Irs Upgrade Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Grabbin' Asphalt Wheels-Tires Fox Rear Wheel Studs Fox 5.0 Mustang Tech 24
90lxwhite Fox Rear Main 1 Or 2 Piece 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
R Fox 4-lug Rear Disk Conversion Parts List - Help Fox 5.0 Mustang Tech 4
hoodrich racing SOLD Brand New Never Used Ssbc Fox Rear Disk Brake Kit. Wheels Tires Brakes 2
jeremy canter fox body rear axle with 5 lug converion Exhaust Parts 1
JV93LX New Moroso 47510 Rear Drag Springs For Fox Body Mustang Suspension Parts 2
Anaconda Fox rear disc 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
R can I use a fox body rear in my 96 gt SN95 4.6L Mustang Tech 13
I Rear Suspension for Fox Bodies Fox 5.0 Mustang Tech 0
