I recently purchased a 1990 lx roller. It was an original 5.0 AOD car. I found a complete 5.0 and T5 out of a 1992 GT. Here is my problem - when they removed the motor from my car the cut the fuel lines just under the disconnect. When I picked up the motor they cut the lines close to the same spot and left the disconnects hooked to the motor. (see pic) If I can cut the lines off the barbs on the disconnect fittings, do you think I can heat up the lines from the firewall with a heat gun and push them onto the barbs? I would love some feedback and different ideas. Also I'm not sure what line is the return and feed line from the injector rail. Thanks!
