Fuel Pump ?'s How many GPH?
  • Thread starter Thread starter bad68coupe
  • Start date Start date Dec 28, 2006
First Prev 2 of 2
xoxbxfx
3,959
Southlake, TX
Dec 29, 2006
#21
  • Dec 29, 2006
  • #21
jcode68 said:
What is the reason for going to an electric fuel pump? The requirements for your engine are well within the abilities of a mechanical fuel pump, unless fuel injection is in your near future? Mechanical pumps are reliable, cheaper, quieter and easier to plumb. If you do decide to go electric, you may want to research how loud the pump is before buying. Some of these things sound like small air compressors when they are running. My 2 cents ;-)
of course there is a reason... its a PITA I Agree though, a mech pump is much easier and can flow what he wants.
302 coupe
1,952
Macon, Ga.
Dec 29, 2006
#22
  • Dec 29, 2006
  • #22
a stock replacement mechanical pump would work fine for him, as would the stock 5/16 fuel line. No reason to upgrade at the current level unless its for braggin' rights.
bad68coupe
220
Richardson, TX
Dec 29, 2006
#23
  • Dec 29, 2006
  • #23
Alright, Alright, Alright, ya'll have com very close to talking me into it. I think i am just going to go with a mechanical. But one more question, where does the filter go?
As far as the switch for the electric pump goes, couldn't it just start up when i turn the key to accessory?
And im not racing, there was some guy in here talking about an emergency shutoff switch and all other kinds of doo-dads, is that necessary for the street?
D
D.Hearne
11,730
south louisiana
Dec 29, 2006
#24
  • Dec 29, 2006
  • #24
With a mech pump, the filter goes between the pump and carb. But I also like to run a filter before the pump too, unless it causes problems (some pumps do OK with em, some don't) Can't have enough filters, dirt is the #1 cause of carb problems. With an electric, the pump needs to turn on with the ignition. An Emergency kill is a must, not just for racing. They're just as needed on the street, if not more than racing. When you get into a wreck and you're incapacitated, strapped or trapped in the car, you really want an electric pump still supplying fuel ? Nothing that's been suggested here in an electric pump system could or should be called a "Doo-Dad" Even with a low pressure pump, you still need a regulator, run it without one and you'll likely have problems. With a carb, the fuel pressure is only there to push down the float in the fuel bowl to lift the needle off the seat,and let fuel flow into the bowl(s) it takes very little pressure to accomplish this function. Too much pressure and you flood the carb, eventually dumping fuel either into the carb throats (marine carbs are designed to do this) or all over the top of the engine.
bad68coupe
220
Richardson, TX
Dec 29, 2006
#25
  • Dec 29, 2006
  • #25
You're right "Doo-dads" was not the right word but i was intimidated when i saw:
"Use an inertia cutoff switch or plumb the fuel pump relay thru the oil pressure switch (ie zero oil pressure turns off the fuel pump - you will need a jump switch to bypass this for startup)"
That made it sound terribly dificult.
Iamdiffrnt
197
South of Detroit, MI
Dec 29, 2006
#26
  • Dec 29, 2006
  • #26
An inertia switch isn't difficult, same thing they have on all new cars, hit a bump too hard the fuel pump shuts off till you push the button to reset it. Two wires, just hook it in between ignition and pump. The big problem is finding a convenient place to mount it.
Ron Francis Wire Works has them, i'm sure others do also, or you could just grab one from the pick and pull.
69gmachine
576
Southern Maryland
Dec 30, 2006
#27
  • Dec 30, 2006
  • #27
Inertia switches are also directional; you should mount at least one longitudinally and one laterally (for side impacts). If you decide to gamble with your life and only want to install one, I'd recommend that you mount it longitudinally near the rear bumper, to protect from a rear end collision. I only say this because you have more control over your fate with a front end collision than a rear one, and I'm not going to assume that there will be enough force to disengage the switch at the opposite end of impact.
Mechanical is sooo much easier and safer. Use the inexpensive street/strip Carter pump, and you can upgrade it to support over 700 HP should you ever desire. They're rebuildable, so it will last for the life of the car.
bad68coupe
220
Richardson, TX
Dec 30, 2006
#28
  • Dec 30, 2006
  • #28
How do the mechanical units shut off in-case of an accident?
thehueypilot
1,084
Medina,Tennessee
Dec 30, 2006
#29
  • Dec 30, 2006
  • #29
Basic formula for determing GPH for fuel pump = BSFC (brake specific fuel consumption) 0.4 (N/A carb) X 300 HP (HP @ flywheel) = 120 lbs/hr
120 / 6.2 (one lbs of gas) = 19 gal/hr
D
D.Hearne
11,730
south louisiana
Dec 30, 2006
#30
  • Dec 30, 2006
  • #30
Works like this: Car impacts brick wall (or other immovable object) Engine stalls. Fuel pump also quits pumping do to the lack of force driving the pump lever (commonly called a fuel pump eccentric mounted on the front of thecamshaft):SNSign:
bad68coupe
220
Richardson, TX
Dec 30, 2006
#31
  • Dec 30, 2006
  • #31
0.4 / 6.2 (one lbs of gas) = 19 gal/hr
I don't follow, from what i typed i derived: BSFC * .4 * HP = X lbs/hr
and then .4/6.2 (Don't know where these numbers came from.
I understand that you take your lbs/hr and multiply that by gal/lb, is that what the .4/6.2 stands for?
thehueypilot
1,084
Medina,Tennessee
Dec 31, 2006
#32
  • Dec 31, 2006
  • #32
Sorry that was a typo it should of been 120/6.2 to convert to 19 gal/hr. I run a Carter "black" electric fuel pump in my race car and it has about 700 HP at the flywheel so a 100 gph fuel pump is plenty for my combo.
fasttback
471
Northern CA
Dec 31, 2006
#33
  • Dec 31, 2006
  • #33
How well do mechanical pumps work above 6500-7000 rpm range?
brianj5600
1,964
Middle TN
Dec 31, 2006
#34
  • Dec 31, 2006
  • #34
I believe NASCAR uses them up to 9000+ rpms. There is no way I would put an electric on unless it was needed.
First Prev 2 of 2
Fuel pump reccomendation
  • jimzzilla
  • Feb 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 21, 2025
85GTStangGuy
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Electric fuel pump in-tank-conversion for carburator
  • extra_stout
  • Feb 16, 2023
2K
1974 - 1978 Mustang II Talk & Tech Feb 16, 2023
LILCBRA
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
13K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
