"ok, yeah im sure its been covered a thousand times before, im just new to the foxbody stuff, the 94-95's have a completely different setup, same block, but alot of stuff is different. ok, well i have the egr blocked off at the heads, so i wont be having the gases flowing up through there. and i dont have provisions on my coolant transfer tube for those lines anyway since its a 95 gt, so as long as there is no function except to cool, then i wont bother to try and connect them."
I dont know about the SN-95 intakes but the Fox intakes have the EGR gasses flowing through the intake through a hole in between the runners. the gasses are not flowed through the holes in the back of the heads, well they are but not the EGR gasses. If i were you i would leave the EGR hooked up, the computer will pull fuel and add timing, because it can not sense the gasses in the intake, it just thinks they are there. If you dont hook it up without properly deleting the EGR via Tweecer or chip then this could lead to detonation or (pinging) and worse gas mileage. I wouldnt delete it do a search and read what everyone says about it. I would also hook the coolant lines up because like said before they cool the hot ass exhaust gasses. Just my .02
