I'm installing a water temp and oil pressure gauge in my '87. I'm going to tap my backlights into my headlight fuse. How do you get around to the back of the fuse box? I can't seem to pull it through or twist it around.
RYC CUKR said:I tapped into the wire coming from the dimmer for my gauge lighting so that I can control it along with the dash lights. Not sure if you can do that with tapping directly into the fuse box. either or should get your lights on though.
That's not funny. Put the correct fuse back in ASAP.EZMachN said:I have a 25amp fuse plugged into #13. Is that bad? Because I heard it was suppose to be 5amp
HISSIN50 said:That's not funny. Put the correct fuse back in ASAP.
I wouldnt even consider using more than the stock rated fuse. If there's an issue, I'd hunt it down.EZMachN said:I just checked and it is a 10amp in the #13 slot. I bought a 5amp fuse. Should I leave the 10amp or put the 5amp in?
