Fuse link bad?
  • Thread starter Thread starter Creomod
  • Start date Start date Sep 5, 2024
First Prev 2 of 2
nickyb
I gotta say i never painted my nuts, Never Ever
3,037
1,665
163
nevada
Sep 14, 2024
#21
  • Sep 14, 2024
  • #21
What's going on? Did you get another fuse link? Are you up and running?
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
590
137
63
ontario
Apr 6, 2025
#22
  • Apr 6, 2025
  • #22
Creomod said:
what causes a fuse link to go bad? Reason I’m asking is my car has been shutting off. Installed new distbutor today(this morning). It started set timming spout out & now it’s doing a crank no start. Looking for voltage( while crank start is there) I busted out the meter. I do have 12 v injector,at the ignition switch,at the red/green wire on tfi connector,but this time I’m getting 11.3 volts at the coil +. I was getting 12 bolts before when car would just shut off. Can it be that the fuse link was bad then made it worse by cranking? I know sounds stupid but only other thing I did was move/wiggeld the harness in the back where the lights are . Can the coil just be bad?It’s a 89 5.0 coupe t5. Still unresolved from the shut off on hiway but I was getting 12 at the coil then but can it be that it was an intermittent maybe loosing the 12 at the coil & now I lost it completely? Or might I have 2 issues?
I'll say Check your TFi module and try another one it sounds like it might be going bad.
First Prev 2 of 2
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
