FWA brass piece. Do i need it? (Pic)
Dec 5, 2006
153
Ok guys with the fwa , i got a stupid question , when i got my fwa it came with a brass fitting thats suppose to go inside the fwa, when i took off the plastic piece on the cable i tryed to put it on with the fitting , well it did not fit but fits great with out the brass, do i need this piece on there, from what i see i dont but could use a 2nd opinion. Looks like i can just use the allen key and put the screw right on the white piece and not the brass. correct me if im wrong. thanks again:nice:
your picture doesn't appear to show a set screw on the the adjuster to keep your setting. If the piece you have doesn't have a set screw or jam nut then I wish you luck with it. Because it will loose its adjustment on its own.
