If it's all highway miles, I can get better than 30, in town around 23. Thats assuming I don't get on it at all. On a track, I'll burn a tank in one night of test and tune.
If all you do is red light stomp, rinse and repeat, you are going to get horrible results. Your engine needs X amount of fuel to make Y horsepower. Your average car built after 1990 takes less than 20hp to overcome rolling resistance and aerodynamic drag to move at 70mph down the highway. When you use all 400 thirsty ponies to smoke your tires for 400 feet from light to light to light. Your fuel economy will be slightly reduced.
Your engine is a glorified air pump, if you want more fuel economy you can do two things:
Run it at something less than maximum power, reduce your pumping losses or both. That means get your foot out of it and your head into it.
Practice responsible driving habits, limit yourself to one blast per car ride for example.
It's kinda cool that reducing air restrictions will nearly always result in increased maximum performance. Port your heads, get well designed cams, use an exhaust that provides scavenging, and get a secondary economy tune programmed for normal commuting.
Yes, positive displacement blowers use more fuel - Specifically twinscrews because they are always doing work...even off throttle. One of the hallmark designs of a twinscrew is the male and female rotors that when rotated together create internal compression (compression within the housing of the blower). This means that even when not generating boost, twinscrews are doing work. Few roots, and no centrifugals have internal compression, and when not in boost, are simply windmilling.
That being said, superchargers will be a load on the engine at all times if for nothing else than the friction from spinning them. People who see an increase after installation probably have their tuner to thank for optimizing their air/fuel ratios - which from the factory are pretty conservative.
