gasket for sunroof?
  • Thread starter Thread starter allballsmustang
  • Start date Start date Apr 30, 2008
allballsmustang
174
Lehigh Valley, PA
Apr 30, 2008
  • Apr 30, 2008
do they make a gasket for the sunroof latch where those two bolts go through? i siliconed it when i put the new body to sunroof gasket on last year but it seems like im getting a small drip
thanks
jim
04gtboy
83
  • Apr 30, 2008
Water shouldnt get high enough to leak there check your drain holes in the front maybe there plugged !
allballsmustang
174
Lehigh Valley, PA
Apr 30, 2008
  • Apr 30, 2008
its on the top of the sunroof? when it rains or i wash it the water hits the edge and runs underneath
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 30, 2008
  • Apr 30, 2008
No one seems to make anything other than the Weatherstrip for the Sunroofs, I found it best to pick up some used roofs for parts.
88wutangstang
Bloomington
Feb 23, 2010
  • Feb 23, 2010
Do you have to acctually remove the sunroof or can it stay bolted on?
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Feb 23, 2010
  • Feb 23, 2010
you do know that the sunroof is removable right?
its not bolted in, just hooks into the roof.
Take the sunroof out and blow out the tubes in the 4 corners with an air hose. should stop water build up. be careful not to use too much force as you can accidentally detach the tubing from the nipple.
Sunroof Woes
  • TIGGER
  • Feb 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2025
Snakbytn1990
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
