  • 2005 - 2014 Specific V6 Tech
Gauge problems
  • Thread starter Thread starter teemotang
  • Start date Start date Nov 25, 2008
T
teemotang
  • Nov 25, 2008
I have the cover off my gauge cluster, as my gauges have been messing up. Usually the speedo and heat can read more than they actually are. I disconnected my gauge cluster from the cable, when I hooked it back up the dials moved and now I can't keep the tach reading right. It goes to below 0. Even when I turn the car on and move the RPM needle to 750 RPM at idle, it's fine when I give it a regular amount of gas, but if I goose it it "slips" and when it comes back down it will read alot less. How can I reset my tach correctly? And the whole instrument cluster for that matter. 2005 V6 Stang. Thanks!
whyask
735
Sacramento
Nov 26, 2008
  • Nov 26, 2008
tee can you do me a huge favor !!! Tell me what bulb size are in the gauge cluster..if you can ! ANd Sorry I cant answer your question ... ;(
E
Evil Twin
Western Oklahoma
Nov 29, 2008
  • Nov 29, 2008
Did you remove the needles for a gauge face replacement or simply disconnect the gauge cluster? Curious why they would be off calibration by simply by disconnecting the harness. I've changed out a gauge plate on my sport bike a few years ago and had something similar happen, I found out I stripped the knurling off the needle which let the shaft spin a little bit inside the needle. I used clear RTV silicone and glued the needle on to the shaft at "zero", never had a problem with it since.
E
Evil Twin
Western Oklahoma
Dec 10, 2008
  • Dec 10, 2008
Whats up with this jerk off posting spam on every thread??
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
T
2002 V6 3.8L Help Me
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
J
Speedometer cable
  • Jimwbx
  • Sep 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2025
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
