Roush gears
C.Saleen
228
i have a 2002 s281 sc
and im looking to start doing some stuff to it
i have tri ax shifter and a bassani off road x
i was thining gears 4:10
chicane 66mm puley
fuel pump not sure wat kind
maby the shm blower cams
heards
any help would be appricated
chicane 66mm puley
heards
I would be more prone to looking at 3.73's instead of the 4.10 especially if your doing any HWY driving. You'll get a very nice response from the switch of 3.27's to the 3.73's. The Pulley would help, as would porting the blower/intake. Cobra owners are seeing 30 rwhp from this procedure. Long tube headers will only net you about 3-5 rwhp but will add over 25 ft lbs of torque. Some some areas to look at. I would start with gears 1st. :nice:
Would LT's gain alot of torque on my n/a 03?
Man, that would be awesome.
Sorry mang, not trying to steal your thread.
NA, not really. You'll gain some but not nearly as much as the blower cars. 5.0 mag did a test on long tubes on the '03 corba about a yr back, it showed a gain of 2.7 rwhp but 22.3 rear wheel torque.
C.Saleen said:
will i need a fuel pump with the pully and where can i have the porting done how much does it usualy cost and does any one in the boston area do it?//
Dont know about your location as I'm on the West Coast, but chat around with other stangers in your local area for resources. No you wont need to upgrade your fuel pump with any pulley. As for porting, most any port/polish shop can do this. Might try posting your question about the porting on the SVT forums.
C.Saleen said:
will i need a fuel pump with the pully...?//
Before adding a smaller pulley, you might want to check the air/fuel ratio on a dyno to verify the tune and/or state of the fuel system. Some cars with stock pulleys and pumps run on the lean side in the upper RPM range. I don’t know what they would tell a person over the phone but on their web site, Chicane has recommended checking A/F when performing pulley swaps.
Better to be safe than sorry.
