Got the longtubes installed today
I like the throatier sound of the H-pipe as opposed to the X but I feel like I lost bottom end torque and the car actually sounds quieter under 3k rpms. Has a nice growl when I open it up though.
Is this normal?
Completely different sound going from the O/R X and stock manifolds to the LTs and O/R H. Thinking about maybe switching to Magnapacks since I think this catback is getting pretty rusty and beaten.
LT's quiet things down until you mat the gas, nothing to worry about there.
As far as losing bottom end, not sure. I was always under the impression longtubes help with low end grunt as well as top end power.
My LT's definitely quieted things down, more so down low than at WOT. I'm actually looking at a louder catback right now to compensate.
I didn't notice any decrease in performance down low but I did notice a little more pull up top.
I noticed a big loss in low-end with just an O/R H but much more pull up top. I think that on these motors, freer-flowing exhaust affects back pressure pretty significantly and thus affects low-end TQ production. However, as RPM's increase the importance of BP is deminished and the increased flow of exhaust gases allows for much improved performance up top......I think lol.
You're not loosing anything down low, probably feels that way because the car is not as loud. LT's will provide more TQ than stock manifolds.
Yup, absolutely. An offroad H or long tubes are not going to hurt low end torque. Back pressure is a badly mis-used term and I want to clarify that a little. You want to as little back pressure as possible without hurting exhaust velocities in your operating range. So the real concern is exhaust velocity. Going to 3" pipes would significantly reduce the exhaust velocity and hurt low end torque. Similar is true on the header primaries. A 1 5/8" primary on your header will be fine. If you go bigger than 1 3/4" primaries, then you would probably loose low end torque and gain some top end. Even bigger, and you would probably loose power over the entire operating range.
Thanks for all the replies. That's a good point on the car being quieter and possibility causing me to think it's not moving as fast haha
I was looking at the stage 8 box of bolts today and noticed there was a bunch of the pointy things left over, which I believe they give a bunch of each size so you can choose....BUT there were also 2 header bolts left...
Not sure if this was manufacturer defect or this guy didn't put 2 bolts on somewhere...Gonna see if I can reach my hand down there today and feel for 8 on each side.
Could this cause any issues? I'll probably take the car back to him if I can't get it on myself.
I was recommended to him by 2-3 people so he's supposed to be pretty good, and that price really did surprise me, especially with the original quote of $300 before he needed another hour.
I know the SCE gaskets I gave him are embossed "this side out." Hopefully he noticed that too :) I HATE exhaust leaks.
I definitely still hear something but could it be the valves/lifters? Is this common?
As far as back pressure and exhaust velocity...the Magnaflow catbacks turn into 3.5" tips I believe, how do you feel about that? Thinking about maybe replacing it anyway. I hear funny rasp noises here and there and it doesn't look that great.
No the valve and lifters should not tick unless they are worn badly or are failing/have failed.
Did you notice the tick before the header install?
And the tips aren't going to do anything as far as changing the size for performance/adjusting exhaust flow unless you went to a much smaller size and constricted the flow of exhaust.
Yeah it kinda seems like it's been there for a while, but could have been an exhaust leak with my stock manifolds. These LTs shouldn't be leaking. I'll have to get a video tomorrow, maybe you guys can tell.
What kind of noise is it, where about is it coming from the engine?
Spark plugs can tick if they back out. It's usually a sign they're about to blow out of the head, may not be a bad idea to check them.
I'm deaf but it kind of sounds like it is coming from the driver side valve cover. I need to do a thorough inspection of both sides and get back to you. It's hard to pin point, but I will also post a video.
It's not really noticable unless you rev it. The only time it really stands out is if I'm next to another vehicle or driving by a wall you can kind of hear the tick/whiz.
I just finished up my Lt's this weekend as well.
BBK Lt's with a catted H and SLP LM1. She quieted down a bit below 2500rpms, but at 3k+ she screams. Actually a bit too raspy for me, but I'll live with it.
As for power, it feels like she gained it all in the top end, feels the same down low as stock, but once she hits 4k+ she pulls a bit stronger.
