I'm gonna talk about your post #3 in this thread first.
I see that you had some stuff that was not like it should be and found it AND most important of all ....... corrected that stuff. IMHO, all kinds of stuff like that needs to be in correct working order or your tuning efforts will not be nearly as effective as they should be.
First things first!
If you are gonna use the older 1.20 software make sure everything is all V1.20 like ccf files, datalog files, and the same basic file loaded on all 4 switch opsitions. I have avoided 1.30 all toghther so I have no experience with it other than looking at a few datalog files Barney sent me. I can say for sure that V1.20 dlog files have a dbf file ext and V1.30 have a db file ext. Again, like I talked about in another thread of yours, I think you can have probs switching back and forth between different versions of software. Maybe Rick or Dave or John or Barney or some of the other Tweecer users can fill in the blanks but, ...... strive to get started with a clean slate as they say.
CManT1914 said:
Okay I used CalEdit 1.20, and was able to datalog some stuff, just sitting in the garage idling. I noticed that my O2 sensors were reading up to 1.7volts under throttle, and just sitting there idling they would jump up to 0.9volts. That CAN'T be right. I thought they were supposed to read 0.45 volts or so.
At this point I would not worry about all that kind of stuff. If they are switchng back and forth with good activity then consider them good.
Also, my injectors were reading 1.4 or so at idle, and up to 13 under throttle.
I assume your talking about 1.4 pulse width values and that is would not be uncommon for your current state of tune.
How do I interpret this? I know injectors are supposed to run at 85% duty cycle for optimum performance, is 1.4 actually 140%?
More stuff that at this time that IMHO should be put on the back burner. You got 30's ...... plenty of inj so no worries.
Honestly, Chris ...... I know you are excited about your new combo and all but your not gonna get everything all dialed in by tomorrow night. It is gonna take a while and your focus should be on:
1) obtaining a decent idle
2) obtaining decent closed loop driving conditions
3) tuning for max power
I'm thinking about turning off my O2's and seeing if it runs better from not reading them.
My opinion about that is ...... I can't stress enough how strongly I think you should not do that. To tune your car to operate off the tables alone is a very advanced kind of tuning thing. You need a wide band to do it and I don't think you have one at this time anyway. Just don't do that.
Looks like I'm finally making some progress!
I agree
A few thoughts about the three goals above to get you started.
1) Look at the throttle body airflow scalar and isc nuetral idle air flow function. See EEC Analyzer notes for help as each combo is different.
Load in the offsets for your 30's
Low slope at 33-36
High slope at 30
See if that gives you a better idle
2) Use your kamrf's to give a more stable closed loop driving condition. Again use EEC Analyzer's excellent help notes for details. This can take some time but can yield great resusts.
If after some time you don't seem to think you are making much progress, I would just blow off the GT t4m0 file all together and move over to the Cobra j4j1.
3) Again, 1 & 2 is way more important than max power but knowing your chomping at the bit for more power
I'd do stuff like kill the tip in retard, high speed fuel enrichment, and the like.
Don't be hosin around with the fuel tables until you get your wide band.
That ought to keep you busy for a while
I know you addressed me in your thread title but ...............
some of you other Tweecer users feel free to throw in your two cents worth as well. If you think I missed something or maybe think I'm leading Chris down the wrong path speak up as I'll be the first to say I have not learned it all for sure.
Have Fun Chris
Later
Grady
