manicmechanic007
5 Year Member
akaNYer, Sometimes the sticker is on the receiver dryer but no worries just go with 2.2 lbs. Only replace the hose that leaks is what I'd do. I assumed your leaking hose would be a manifold assembly that bolts to the back of the compressor. Either way replace it and evac and recharge. Your orifice and other lines and hoses if not leaking are and will be ok. The compressors last indefinitely. Just because it is 25 years old is no reason to replace it. Noise on the other hand... If the car blew a bit of cold air means the compressor is working = good. The fact that it blew warm after the initial turn on just means it was low on freon and the clutch cycling time was incorrect due to the low freon. I would replace all the o rings you can easily get at. Both sides of the condenser for sure and the high side line(s) back to the evaporator. The low side o rings seldom leak
ton of refrigerant; last you the rest of your life. At the end of the day it's going to cost you like $50 more than buying a bunch of little cans. If you use the little cans, you have to purge out the gauge lines between every can, and it really increases the chances of getting air in the system. I personally just don't waste my time with all the little cans. Those are more for topping off AC systems that are a little low. If you are buying a new high pressure line, then it's going to have a new orifice tube in it, so you don't have to worry about that. You should replace the drier canister. Any time you open up the AC system, the drier can absorb moisture from the air. Moisture in an AC system is really bad. Almost all the oil is inside the compressor itself. The best way to do it is to remove the compressor, drain the oil and replace it with a measured amount of new liquid oil.
