GT40P Compression with SpeedPro Pistons
nito88stang
2,012
Fullerton, California
My engine is in the machine shop as we speak. I'm having it built with SpeedPro Pistons that produce a compression ratio of 9.08:1 with 58 cc heads.
I cant seem to find out what CC the P heads have because online they say it varies from 59 to 61 cc. I want to have AT LEAST 9:1 compression or a tad bit more but under 9:5 (future boost maybe).
Lets say worst case they are 61 cc, what compression would i have with my 306 and these pistons? How much would i have to mill to have the compression fall in the range i want? I will be using the stock cam for meanwhile until i'm out of college, will there be any piston to valve clearances if i mill them say 0.030 ??
Thanks :nice:
If you MILL the heads, your compression will INCREASE.
An easy and less expensive way to measure CC per cylinder is to buy a syringe like this, Universal Pump Dispenser, by Hyde Tools, at most paint or hardware stores (Item #30460) for about $5.00, then buy a small piece of thin plexy glass..drill a very small hole(1/8th, about 3/4 from the edge of the plexy glass). Add grease around the combustion chamber, put the plexi glass over the C-Chamber.
Now keep filling the combustion chamber with water and keep track of how many CC's are added to it.
Use the attached image to tape over the syringe to know how many CC's are being added into the syringe.
Make sure your spark plug is IN the hole.
Also , I would personally just give it a quick spray of WD40 and wipe it down before doing this, because it will cause flash rust.
Now after you have done each cylinder head, and made sure each one is even @~61cc per chamber, then you read everything below and figure it out!
If your head CC is not matching, nothing a dremel cant handle. Remember one glob of water is one CC(size of a DIME almost).
I know this is for a CHEVY, but same concept.
The calculation of compression ratios (CR) is based on the following formulae:
Compression Ratio = (Swept Volume + Top Dead Centre (TDC) Volume) divided by TDC Volume
Swept Volume = (pi x Bore Diameter x Bore Diameter x Stroke) divided by 4
TDC Volume = Head Volume + Gasket Volume + Deck Volume + Dish/Dome Volume
Head Volume is published or measured in cubic centimeters (cc).
Gasket Volume = (pi x Gasket Bore x Gasket Bore x Compressed Gasket Thickness) divided by 4
Deck Volume = (pi x Bore Diameter x Bore Diameter x Deck Clearance) divided by 4
Dish/Dome Volume is published or measured in cc.
Note: Any volume below the piston compression height is a positive value. Any volume above the piston compression height is a minus value.
Dimensions: When calculating, use cubic centimeters (cc) or cubic inches, but not both. Refer to the following conversions:
1 inch = 2.54 centimeters (cm)
0.061 cubic inch = 1 cc
1 cubic inch = 16.387 cc
Example: Find CR for a Chevy 350 using 0.03 inch oversize pistons with a Dish/Dome Volume equal to 5 cc:
Head Volume = 76 cc = 76 x 0.061 = 4.636 cubic inches
Dish/Dome Volume = 5 cc = 5 x 0.061 = 0.305 cubic inches
Gasket Thickness = 0.035"
Gasket Bore Diameter = 4.166"
Deck Clearance = 0.005"
Deck Volume = (pi x 4.03" x 4.03" x 0.005") divided by 4 = 0.064 cubic inches
Gasket Volume = (pi x 4.166" x 4.166" x .035") divided by 4 = 0.477 cubic inches
Swept Volume = (pi x 4.030" x 4.030" x 3.480") divided by 4 = 44.389 cubic inches
TDC Volume = 4.636 + 0.305 + 0.064 + 0.477 = 5.482 cubic inches
COMPRESSION RATIO = (44.389 + 5.482) divided by 5.482 = 9.097
Now, those of you who only sleep well at night having measured Head Volume and Dish/Dome Volume yourselves are undoubtedly saying, "published values can introduce error into compression ratio calculations". Well, you're right, and if cc-ing equipment is at your disposal, using it can help achieve an accurate compression ratio, which in turn can be used to calculate the optimum camshaft profile for the application.
All in all to sum it all up: This is a basic formula...
Compression Ratio
CR = ( V1 + V2 ) / V2
CR is compression ratio
V1 is cylinder volume at exhaust closing
V2 is combustion chamber volume
GOODLUCK!
Pete
Also for boost it is great to go under 9:0 or stay at 9.
