gt40p heads?
  • Thread starter Thread starter montyd
  • Start date Start date Oct 22, 2006
montyd
114
  • Oct 22, 2006
i am looking at getting a set of heads off an explorer like everyone does. and i saw a forum on here where someone said there is a comparison of explorer and gt40 heads and the pros and cons of it on stangnet but i cant find it. does anyone know or have the link? any help would be appreciated thanks fellas
Brett88lx
65
  • Oct 22, 2006
This may or may not help but I always assumed that the cylinder heads off an Explorer WERE GT40P's.
montyd
114
  • Oct 22, 2006
i know they are gt40p heads i want to know the difference betweent eh gt40p and the non p heads
9
95GTAODE
200
  • Oct 22, 2006
'96 to early '97 came with standard GT40's, while
mid '97-'01 came with P's.
-40's can be identified by 3 lines cast into the ends of the heads,and "GT" cast into the rocker valley and beside the lower rear head bolt hole.
P's have 4 lines and "GTP" cast into the same places.
P heads also have 58cc nominal chambers compared to 62-64cc for the standard-40's, as well as a smaller exhaust valve that promote's velocity, along with the spark plug relocated closer to the center of the chamber.
All told, P's are probably worth 10-15 hp over the regular 40's.
The relocated plug angle is why P's need specific headers.
montyd
114
  • Oct 22, 2006
so my shortys that are on my car now wont work with the new head from an explorer?
9
95GTAODE
200
  • Oct 22, 2006
Depends what year explorer... '96 and early 97's have standard GT40's, so you would be fine.
If they are off of a mid-97 -01, they are P's and require a P specific header... FRPP and MAC make P shorty's, and, while nor designed for P's, BBK and MAC long tubes do work.
V
v8only
2,378
22
49
Oct 22, 2006
  • Oct 22, 2006
in my opinion, the differences functionally are negligeable and debateable. The only difference imo worth considering is that the spark plug angles of the p heads require ford racing shorty p headers, or mac p headers (garbage), or some wicked 90 boots and customizing on headers. Not a big deal though, those ford headers are just over $200 on summit in stainless form, and give you tons of access to the plugs.
90
Michigan insane asylum
Oct 23, 2006
  • Oct 23, 2006
i no about the 4 slash on the gt40p's and 3 on the gt40's... i thought the gt40 were iron.. and the gt40p's were aluminum?/? im not 100% sure but is that true ?
V
v8only
2,378
22
49
Oct 23, 2006
  • Oct 23, 2006
they're both iron heads, i'm running an entire 97 explorer motor now with the p heads.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 23, 2006
#10
  • Oct 23, 2006
  • #10
Everything you want to know about GT40P heads
D
dcrab
10
#11
  • Nov 27, 2006
  • #11
Tri-state offers some p's with 1.94/1.54 valves. I understand that factory was 1.84/1.46. Are the larger valves a good improvent over stock for this peticular head?
L
Lxstang306
33
#12
  • Nov 27, 2006
  • #12
gt40p have diff exhuast ports thats why not all headers will fit them spark plugs have been moved to.
millhouse
1,985
Simpsonville, SC
Nov 27, 2006
#13
  • Nov 27, 2006
  • #13
The exhaust ports have nothing to do with fitment issues...it's all in the plug angle.
jtfairlane
468
#14
  • Nov 27, 2006
  • #14
The exhaust ports on GT-40P heads cause no issues with just about any small block ford headers. The exhaust ports are a "redesigned" port in comparison to an E7TE head or a standard GT-40, but they are not a raised port or anything else that would require different headers. The only reason they require unique headers is because of the revised plug angle.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
