- Jun 21, 2017
- 143
- 15
- 28
Looking at a car that has a rebuilt motor from 2009...motor only has about 40k on it. Unfortunately I don't have much information on the car except this engine build sheet -
Factory 5.0 Block, Stock Forged Pistons with High Tension rings, honed bores.
ARP rod , main bolts and head studs
Stock 5.0 oil pump
Balanced bottom end
Comp Cams custom cam 218in/220ex degree .512/.512 lift/114 lobe centres
Ford Motorsports roller lifters
Edelbrock Performer Aluminum heads 1.94/1.60 valves
Chambers reshaped and blended at valve seats
Multiangle valve job
Cut for Felpro wirelock head gaskets
Intake ports matched to Felpro 1250 intake gasket
Exhaust Port walls blended from cnc port opening into runners
Extrude Honed Ported
Comp Cams dual valve springs
Crane HD pushrods
Ford Motorsports Cobra intake manifold
Ford Motorsports 65mm Throttlebody
24lb Ford Motorsports Injectors with 190LPH fuel pump
MSD Billet electronic ignition distributor
MSD 7AL ignition module with MSD wires and cap
Crane H.O Coil
Sorry for the wall of text...I'm waiting to hear back from the company that built it but looking for some guesses.
thanks
EDIT - Exhaust is
BBK Ported 1 5/8 equal length headers
Bassani X Pipe with High Flow Cats
2.5 inch borla mufflers
Has underdrive pullies and KN intake.
Stock 5.0 oil pump
Balanced bottom end
Crane HD pushrods
Crane H.O Coil
thanks
EDIT - Exhaust is
on a wall.
