mackey said:You really won't need a tune. My mods are in sig, and i haven't done anything for tuning yet and I am running high 13's. That is just with the mods in my sig. No gears. no afpr. no dr. nothing. just trickflows kit.
17yrOldStanger said:no offense, but thats actually horrible to run high 13s with an HCI. maybe you should tune it......
mo_dingo said:Here comes the
So you think he doesn't have traction issues? He is probably running 8" street tires with stock suspension. I bet the best 60' time he can cut is a 2.2 or a 2.3.
I woud also wager that when he shifts into 2nd gear, and punches it, the car goes sideways unless he lets off.
Just h/c/i with NO OTHER MODS & running high 13's is very understandable & logical. Add some suspension & DR's and he will see low 13's IMO.
Scott
White95V6 said:Well, I have decided to go with heads, cam and intake over the winter. I want the Edelbrock Performer Heads( http://store.summitracing.com/default.asp?target=partdetail.asp&part=EDL-60329), and the Edelbrock Performer RPM II Intake. What cam should I go with, what other parts will I need. Im am new to all of this. Do i need new rockers, I know I want to go to #24 Injectors. Someone who has done this please list everything I will need to buy to complete a H/C/I swap. Thanks
5spd GT said:The RPM II is to big for the 302 for daily driver and have the nice "fun" low rpm torque for around town driving...if you think you can make a custom cam to make up for that high flow of intake and keep it at a nice flat torque curve across the board...there is a little bit more to it than that...For example: You could lose some mid-range or high range by grinding the cam for some torque "gain" to compensate...
Good Luck
His mph is 113.xx and he hasnt even dyno'd the new changes yet. Very impressive. Stock short, trickflow TW heads, FTI cam, rpm 2, 75mm tb, 30's, pro m 80, longtubes, 410's and a C4. Theres more in it after he dyno's it. I gotta PM him and see when he's gonna do that.
nmcgrawj said:Does anyone actually have real proof of this statement? I see and hear a lot of guys saying it....but does anyone actually have real life proof? Sure you think what you think on paper but it doesn't matter if its not ran on the car to back it up. Just a little tired of guys saying this without any proof. And dont say custom cam designers say it....cause different cam designers have different beliefs and strategies.
BTW, what starts the intake charge into the cylinder?
Grn92LX said:nmcgrawj, I so bad wanna do a holley intake and a Jay allen custom grind. I just spent a lot of money though recently on a tremec TKO, clutch, driveshaft, scattershield, new pro m 80mm maf for 30's and an accufab 75mm TB. Once I sell my other 24lb pro m 80mm maf and accufab 65mm tb I may go for it. I'm also owed money from a side job I did with my buddy from work. It never ends![]()
I would just compare the dyno results from some milder combos which most seem to think will have good low end and midrange power to a few more radical combos which most seem to think will make more high end power but will be somewhat softer in the lower rpm range.
Grn92LX said:He should put a cobra intake on to "gain velocity"![]()
5spd GT said:That would be stupid...you actually know someone on here that would suggest that?![]()
nmcgrawj - Ask Ed if that RPM II is to big...see what he says...I wouldn't want it on my car even with a "custom cam"...I know a guy that had a Systemax intake on his car and I know what it can and can't do...let's just say you had to build it on up...
nmcgrawj said:I didn't realize the difference in size with the RPM II and RPM. In tests that it is involved with, the Systemax intake blows everything away in n/a and forced induction.
Im not sure what you mean by "build it on up" but intake velocity due to the intake is bs if you ask me when comparing intakes with runner sizes that are fairly close. The intake charge is actually started or initiated by the exhaust down in the collector of the header....not by the piston going in down the cylinder or something else that i thought at first. The cam controls the speed of the exhaust...how fast it leaves thus how fast the intake comes in. The drop in pressure the exhaust leaving causes the intake to be pulled in. Anyway, Jay Allen explained this to me on the phone which makes me believe that the cam does make intakes that differ in size...by nothing huge though....be able to perform the same if not better.
Anyway, we will see next spring. We could be wrong though but i dont think the Holley intake is THAT much bigger than say a performer or something.
5spd GT said:I would like to see your dyno sheet when it is all said and done...(spring)...
I meant by "building it on up"...is that it really only pulled at just before 5k...
Come on man, you cant seriously think that he put that combo together right with good heads and the CAM that handled everything correctly.
