H-pipe brand, does it matter?
I'll looking at off road h pipes, and I was wondering if any of you guys have used the cheap H pipes like the ones that Mustangs Unlimited sell for $125.00? BBKs new are $175, are they really that much better? I'm going to just run BBK shorties (already have those ready to go on) and probably a flowmaster cat back 40 series.
Any suggestions on the best place to order these from? I'm going to check the classifieds too.
Thanks.
yep
Fitment and material mostly. Some of the real cheapies I've heard you may have to "modify" to get everything to line up nice. Maybe some slag on the inside too...
More expensive ones are often stainless and will last longer.
Some of the cheaper H or X pipes tend to have ground clearance issues. I ran a Flowtech H on my old Fox and the clearance was terrible. I had an exhaust shop cut a small section out and reweld it to fit closer to the undercarriage when I had them install cats, since I couldn't even make it up the like 3" curb in front of my house without scraping. If you stick to a name brand like BBK, Mac, etc. you should be good.
i have tried flowtech o/r h and had fitment issues. then i switched to MAC. Wow what a difference. came in 3 peices and fit beutifully. couldnt ask for better fitment. only thing is that i wish it wasnt black. would have like it to be silver color to match the rest of the exhaust
Silver high temp paint cures that. The new silver high temp stuff actually looks pretty nice too...
I've found that sticking with the same manufacturers tends to give you an advantage when it comes to fit. I have BBK longtubes and a BBK off-road H-pipe. Fit was great. Went together in a snap. I also have zero under car clearance issues. I also have custom flowtubes running to flowmaster 40's and stock tailpipes. I had to get a new flowtube welded up because my exhisting one was too short, but that comes with the territory.
I suggest buying the same company's headers and h-pipe.
if you need to pass smog, then it DOES matter, the magnaflow h and x pipes are the ONLY carb certified pieces that are legal.
From Pypes Website:
All of our Street Legal crossovers utilize our small, but mighty, 5.0 litre ODBC compliant, catalytic converters. They out-flow most performance mufflers and weigh a mere 2.5 lbs. These are designed specifically to give your Mustang a major wake-up call in both sound and performance. The modular design of these x-pipes allow for conversion from off-road to street-leal and back to off-road with optional cat-delete pipes. Our Catalytic Converter X-pipes will pass emissions inspections in most states. Check your local and state regulations for installation and usage guidelines. Gain 8-12 HP and a unique sound!
Passed smog in New Jersey with them.
