I ordered the Starter Box from Maximum Motorsports and so far I just finished up the front H&R springs with isolators, Bilstein struts and MM C/C plates. Although, I didn't take a before measurement, but after I was done I lowered down the front end off the jack stands and measured from the ground to the bottom of the fender fender and it measured 27 11/16's inches. I measured the rear (at stock ride height) and the the rear sits at 28 4/16's inches. A modest 9/16's drop or just over a half an inch. WTF?!?! I know I haven't done the back yet but it shouldn't really affect the front drop at all. What gives? If I messed up on putting the spacers for the strut shaft and put too many will that affect my drop? I'm mechanically inclined but not on the physics and mathamatics end of it. Is there domething I did wrong or something I need to do different?
It really doesn't look lowered at all in the front. Although I care more for handling, I still like a nice lowered look over the nasty 4x4 look.
, you didn't happen to check the static height of the spring first so you could contact MM with the info did you?
Maybe somebody will trade you?
