Hatch rattles bad.
  • Thread starter Thread starter Lyonmt
  • Start date Start date Aug 10, 2007
Lyonmt
110
Tampa, FL
Aug 10, 2007
  • Aug 10, 2007
This thing rattles like a crack whore holding two cans of spray paint! It doesn't look like there is any way to adjust it. Am I wrong? How do I tighten it up?
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Aug 10, 2007
  • Aug 10, 2007
Start with adjusting the bumpers down so that it tightens up when closed. The latch and striker bolt is next step. The striker bolt may need a new bushing and may need moved to align properly when hatch is closed.
Lyonmt
110
Tampa, FL
Aug 10, 2007
  • Aug 10, 2007
I think that may be my first problem... I have to go look, but I don't think I have any bumpers! Can the striker be moved? it doesn't look like it can be. Lastly, where can I get a new bushing? Mine are definitely shot. The last guy put electrical tape around it! Same for the door strikers!
Any suggestions on where to order those parts from?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 10, 2007
  • Aug 10, 2007
The plastic bushing is available in the Help! section of most auto parts stores, but it will require some searching to find it. The washer is screwed on to the bolt, so it may require placing the washer in a big vise and unscrewing the bolt off of it so you can replace the plastic bushing.
Lyonmt
110
Tampa, FL
Aug 10, 2007
  • Aug 10, 2007
Took me two seconds.
I don't think these two will come apart unless there is a saw or a torch involved...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 10, 2007
  • Aug 10, 2007
It will come off, I have done it before. It took a big vise to hold the washer and lots of effort.
Lyonmt
110
Tampa, FL
Aug 10, 2007
  • Aug 10, 2007
I guess you have to thread the washer with the bolt, eh?
EMW150
2,020
Roaring Spring,PA
Aug 11, 2007
  • Aug 11, 2007
Also check your hatch weatherstrip. They shrink over time and allow the hatch to ride loose. A new weatherstrip tightens things up. 5.0 resto has them pretty cheap.
2000xp8
SN Certified Technician
Aug 8, 2003
8,066
1,650
194
NJ
Aug 11, 2007
  • Aug 11, 2007
becareful not to adjust the side bumpers too far, when you slam the hatch they will crack the metal around them.
KdSaint
Florida
Aug 11, 2007
#10
  • Aug 11, 2007
  • #10
I can't remember where I found it, but there was an article explaining how to replace the hatch striker in case it wore down. From what I remember, you take out the older striker and replace it with a T45 torx bit. It's the identical size of the striker and should work perfectly. I'll try tracking down that article.
KdSaint
Florida
Aug 11, 2007
#11
  • Aug 11, 2007
  • #11
sorry for the double post, but this link might prove useful. It's the step by step of the fix I described above.
http://www.automedia.com/Hatchback_Rattle_Repair/ccr20030701hr/1
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,083
224
Massachusetts
Aug 11, 2007
#12
  • Aug 11, 2007
  • #12
If the striker is worn, definitely replace it. Same goes for the doors. Replace what you can as they are cheap but often overlooked parts
These little items like this make the difference between a nice tight car and a rattle box.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 11, 2007
#13
  • Aug 11, 2007
  • #13
You are exactly right about that. It messes up the threads a little, but they still work good.
If you have the right size drill bit, you can drill the hole in the washer a little larger when you put it back together,
D
dbarr
#14
  • Aug 11, 2007
  • #14
Check the spoiler too. My Cobra spoiler was rattling something terrible and I just tightened the two bolts, one on each side under (over?) the black rubber caps on each side of the hatch.
Lyonmt
110
Tampa, FL
Aug 11, 2007
#15
  • Aug 11, 2007
  • #15
I put a piece of vacuum hose over it for now and it works perfectly. I think I'll remove it at work and give it to our machinist to remove the washer and install the new plastic sleeve that I bought. easy peasy. If it becomes an issue, I'll buy a new one. The rubber seal is definitely shrunken and in need of replacement. I had to "adjust" it so that it sits on the chassis properly, but that leaves a 1.5" gap at the center, so a replacement will be in order. I also adjusted the bumpers and the spoiler is definitely tight as it was just replaced before I had it painted last month.
Thank you all for the help and input!!
SuperStang83
1,693
Boyertown, Pa
Aug 11, 2007
#16
  • Aug 11, 2007
  • #16
I would start with the striker as well.
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
