Head install, a few questions
  • Thread starter Thread starter DJCarbine
  • Start date Start date Apr 17, 2007
D
DJCarbine
392
  • Apr 17, 2007
First off, its a 66 289 block.
I am in the process of installing GT40p heads, and an edelbrock performer rpm cam. The GT40p heads came with a set of performance valve springs on them, Dual with an inner and outer spring. The cam says that the warranty will be void if I use dual valve springs, and that I should use the edelbrock brand Shure-seat springs.
First question
Can I run dual springs with the edelbrock cam, or even with the stock cam for now safely
Second question
Do I need to use permatex on headgaskets?
Third question
Why the hell are the manifold studs at the Y-pipe so hard to get off
I broke one off in the manifold, the other 3 came out just barely.
D
DJCarbine
392
  • Apr 17, 2007
For the valve springs edelbrock recommends the seat pressure is 120 pounds. I think the dual valve springs I have are maybe 10 pounds over that.
classic boost
709
canton, oh
Apr 17, 2007
  • Apr 17, 2007
DJCarbine said:
Second question
no.
coolblue65
1,224
Algonquin, IL
Apr 17, 2007
  • Apr 17, 2007
When I first put in the RPM cam when I had my stock heads, I used the Edelbrock springs. When I got my Trickflow heads I used the dual-valve springs that were preinstalled and I experienced no problems with the RPM cam.
D
DJCarbine
392
  • Apr 17, 2007
Awesome, thanks for all the replies guys. As a side note, wrestling in heads by yourself is a PITA. When something that heavy smashes a finger, it doesnt hurt... till the numbness goes away
Max Power
1,774
St Paul
Apr 18, 2007
  • Apr 18, 2007
Cam mfgs always recomend that you use their springs. Spring pressure is more important. Side note: Edelbrock heads come with dual springs.
I always thought cam warranties were a joke. If you wipe a lobe, the price of the cam is the least of your problems.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
