  • 1994 - 1995 Specific Tech
Heater Core
  • Thread starter Thread starter NooSlo50h
  • Start date Start date Oct 11, 2005
N
NooSlo50h
9
  • Oct 11, 2005
I am trying to change the heater core in my 95 GT. Do you have to take out the dash for this? Its proving to be a big pain in my ass. Thanks
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 11, 2005
  • Oct 11, 2005
More then likely yes
GreenandSilver
228
San Jose CA
Oct 25, 2005
  • Oct 25, 2005
So did you do it? I have had a blown core for over a year - just bipassed it. All the shops wanted 700 to 900 labor for it
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 25, 2005
  • Oct 25, 2005
Yeah, it's a royal pita. Some have had luck cutting a square hole in the housing for the heater core and getting it out that way, and just using some aluminum tape to reseal it when you get the new one it. That is how I would do it.
Scott
GreenandSilver
228
San Jose CA
Oct 25, 2005
  • Oct 25, 2005
interesting! I was considering looking into something like that and its good to hear that it may be possible - and surprising at that considering it might be looked at as even a defect if the solution is that easy. I will look into that some more. Do you know anyone or anywhere I could check out to find 411?
R
rockin_rick
968
Oct 30, 2005
  • Oct 30, 2005
I would highly suggest getting a OEM heater core. I bought a replacement from 50resto.com and compared to the ford part, it's not even close. I changed it out before I had a problem, and the OEM core looked near perfect. It is WAY better built, so much so, I considered putting the 10 year old OEM one in instead of the new replacement. I should have returned the replacement and got an OEM... don't want to do this job again soon...
FWIW - while the dash is out is a great time to install a clutch quadrant... super easy!
Rick
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Install 79-93 Mustang Heater Core Replacement
  • AeroCoupe
  • Oct 13, 2025
  • Resource Discussion Forum
Resource Discussion Forum Oct 17, 2025
85GTStangGuy
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
