StaffAmerica74
add me to the inertia switch.... it cuts the fuel off but it might have enough to sputter off the road.
KidTwist51 said:A solution!
Well I just went over to the dealership and chatted with the techs. You won't believe this... actually... some of you will
It was the freaking inertia switch after all. They flipped it and she fired right up. Dean Sellers Ford is as baffled as I am that I had enough fuel in the lines to drive a good 1/2-3/4 of a mile. They said normally when the inertia switch trips people barely have enough gas to get out of traffic to the side of the road and that's it. Everything else seems fine, they're gonna give it a good looking over but it sounds like it's ready to head over to the body shop and get patched up. Obviously I'm thrilled, just completely surprised there was enough gas in the line. Thanks for everyone's input!
-Chris
KidTwist51 said:I also thought about the inertia switch when I finally got it safely off the freeway, but it wouldn't run at all if that had been tripped, so that's not it.
-Chris
its on the inside of the trunk lining right behind the drivers side tailRaceDvr50 said:Should be mounted in the back on the inside between the taillights.
