Help highbeam wont shut off on pass. side
jstang209
Jun 3, 2004
640
Stockton 209
i switched headlights a couple of days ago and barley noticed that the pass side is alot brighter then the driver.. and i notice when i turn the nigh beams on only the driver side gets brighter.. so im guessing the pass side high beam is stuck on sumhow.. neone heard of this happening?? how can i fix it??!! thanks
Jason is right on.
also, if you hit 'flash-to-pass' does the pass side get brighter? IIRC, when the brights are on, it is only the high beam. but with flash-to-pass, both highs and lows are on. If both beams are staying on, i would check the wires in the MF switch.
good luck.
