I want to get the ball rolling with an inexpensive sollution, that will be safe for the motor. First of all, I'm rebuilding right now and putting in KB hyper pistons. I've heard all sorts of claims "they can handle up to a 500HP shot", "they'll blow with a 100 shot".
I figure 75-100 is safe. Going to be pulling timing, running the correct colder plugs, and either 91 or 102 octane. So I dont think I'll run into detonation.
Now I wanted to go with a zex dry kit. "you need 24lb injectors and a calibrated MAF". What? Do I? of should the stock 19lb's be okay? Can I run the stock intank pump? Or should I put in a 255? Do I NEED a adj. fuel pressure regulator and FP gauge? I'm getting frustrated. Can you guys suggest a good setup for me to run? Please?
Thanks.
Thanks.
