Help with FRPP heads/Roller Rockers
92-5.0
California
I am sticking with FRPP for my combo and need help choosing the right heads and roller rockers, while trying to stay at or near the stock compression ratio. I am going to purchase the GT40X heads but don't know if I should get the 58cc or 64cc heads? Also, should I match them to the 1.6 or cobra 1.72 rollers?
The 64cc heads will keep you closer to your stock compression ratio than the 58cc heads, the 58cc heads will give you a slight increase in compression. If you go with the Cobra 1.7 rockers, you should be just fine with Piston to Valve clearance, but I would clay the pistons and check for sure.
Check my mod list below. I went with the GT-40X303 heads for the reason listed above. The FRPP tech line recommended the 1.6 rockers for those heads with the E-cam on stock pistons. This set-up gave me 257 rwhp through the stock AOD. I'm currently collecting parts to do a T-5 swap and I'm expecting to be closer to 290 at the rear wheels when I'm done with that.
