remat457
D347643 said:does anyone have any dyno runs showing a comparison between the tb's?
i have the exact same setup as the guy who started this thread. i think i should go with a 75mm now,
I looked through "5.0 Dyno Tests" and they dyno several TB's but the actual chart isn't really worth much unless you happen to have that exact setup....
BUT....they also conluded:
"Installing a larger 75mm throttle body actually resulted in less power, even on a motor that produced 350 hp with the right combination of components."
so...again it all depends on what you want to do...
, but his works and has good throttle response.
