Hi Guys. My valve geometry looks like the one in this link. Help?
I've been told that you shouldn't concentrate to much on having it perfectly centered, you want a narrow travel. So if it's a little long but the wear is narrow, you'll be fine. Now I'm not saying that you don't need it centered and narrowed, if you get both, then that's better, but between centered or narrow, go with narrow.
heres what it looks like...
picture.php
That is fairly center. I played around with diff. shims to see if going up or down in shim would change it much. I found that it was about perfect with no shim on the stock rockers and the 60's with the 1.7's that I had a run a lash cap on top of the valve that added 60.
if going down or up with the next size shim move it drasticly your as close as your going to get it. I would just play with the shims to make sure.
I even went and used a caliper and measured some washers at the hardware store to see if I could get a shim "in the middle". It did not change it much so I left them out.
