Engine High rev on warm startup??
Ford-Uaw
Ohio
Car idles good at 600rpm, cold start revs to around 1500 drops to 1200 then 900 and then settles at 600, but after getting the car up to temp , on restart it revs to about 2400rpms for about 1-2 seconds.... any help would be appreciated...thx
..1986 gt no mods, bone stock, 60,000 miles,
New- Iac, coolent temp sensor
Tps is set to 97
Egr cleaned
Throttle body and spacer cleaned
Idle reset done..
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 250,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
  • Useful
Reactions: General karthief
I hav did the checklist , The only code I get is 67 and 11, and for 2 weeks I can’t figure it out, switch works , checked wiring with multimeter, the car runs perfect except for the 1-1.5 second high rev at warm startup, I would like to run a koer test , I have read on here today that I can run the test by grounding out pin#30 hope that doesn’t screw anything up..
