holly systemax II question
txgunrunner
68
houston, tx
would a systemax II kit be overkill for a stock motor in addition to maf, tb and gears? does trickflow make a h/c/i kit or are there better kits out there? will this set up get me in the 12's. new to the mustang scene and learning lots. thanks for all the replys.
not to hijack,but can anyone tell me what a ballpark cost is to get the systamax II or something like it installed?I know it wouldnt be too hard to do mechanically but not having time is my issue.
Don't know but I have a suggestion. Put the word out on this forum for someone to install it for you. I think you may find somebody close to you who can do it. We're all friends here :D At like 60-70 dollars per hour, a shop could get very pricey.
I just researched this subject and bought the Trick Flow kit...The Holley is more expensive and comes with less items,than the Trick Flow. The Holley kit is $2209 and the Trick Flow is $2095...Both available from Summit Racing. Trick flow comes with heads, cam, intake,pushrods,roller rockers, timing chain,Arp bolts, valve covers, and gaskets.... While the Holley comes with heads,cam,intake,pushrods,bolts, and gaskets.. The cost of the Holley is higher because of the Systemax intake,but I think the Trick Flow has the best bang for the buck... They produce equal HP # and you get more for your money with the Trick Flow...Plus, the Holley heads performance is questionable,where as the Trick Flows are proven for 302- stroked windsor...If the street intake is not enough for another $50 you can get the Trick Flow Track heat intake.... Hope this helps...
Kelly
