Not that I've seen.Do these things have a habit of dropping dead on their own accord?
Apparently, there are internal fuses that will reset if tripped so either they arent resetting or the computer is just kaput. Ill still send it off
Is there any chance the arcing might have blown a fusible link?Update - I was able to jump the plug on the fuel pump relay from the red to light blue and the fuel pump kicked on.
Next, I'm going to try adding jumpers to the grounds and grounding the computer inside the car and see what that does.
Ive been jacking around with it all morning - I finally unplugged the salt/pepper shakers and turned the key and it all powered up and the fuel pump came on. So, something in the engine harness is grounding out. Ill work on tracing that out next.Is there any chance the arcing might have blown a fusible link?
Bill
Im keeping an eye out for a good used 351Sounds like an impending oil pan failure to me![]()
Bet that Bronco has one!!Im keeping an eye out for a good used 351
Thats what I need the 351 for! This one is toast.Bet that Bronco has one!!![]()
So so so frustrating.Glad you got to the bottom of the wiring issues, I bet that was a PITA.
Well the ad expired and the thumbnail was all I can manage. It's on Fleabay for $550 and I decided I dont need it that bad.I am in-fact [not] looking for one but I would still pay more than the value of the potato camera that the image above was taken with.![]()
