Hopefullynot a dumb ques.. Fuel pressure and nitrous ..
Until you get to a BIG dry shot. I have to bump my pressure manually to run the 125 shot. I crank it up to 43 and the car doesn't run too good N/A like that.
100 shot I let the Zex kit push the difference. If you want to go BIGGER than 100, I would look into a wet kit.
352Ford2 said:
if you get a wet kit it doesn't matter, because the fuel is being supplied by n20 system.
and dry kits only bump up your fuel press when your spraying
Oh! I did not know that. So there is no need for an adj fuel pressure regulator then right? The only thing you really need to do is adjust your timing and get a larger fuel pump right?
I really don't want all those solenoids on a wet though ..and isn't a dry kit easier to install? Also, are you saying with a wet kit there is no need to adjust timing at all? Thanks.
IMOP wet kits are really not that much more difficult to install or place noids than a dry. their are some kits that claim if your engine is stock and your running stock timing, you don't have to change it. that just means you should have been running more timing NA. I recomend about 1 deg per 50 shot assuming you got your timing curve nailed down already. down't forget to run premium and drop down your spark plug heat a few ranges
Stick with a proven/cheap used nos 5115 Dry kit. The kit spikes the FP, you do NOT have to manually change it when you wanna squeeze. I've had both and my dry kit was better. A 255 high press pump is a smart move.
