yep boobies are pretty much the *****
i believe the limiters vary but its between 115-120mph, i checked mine using the electronic speedo function in the odometer and clocked 118. i have seen someones "stock" dyno sheet for 170 something rwhp i use the quotes because i probably cant find it to post up but yeah its a good bit below the 193 crank hp given by ford.
and i believe up there worked v6 meant 4.10 gears not 4.20(must have been thinkin of something else there
and i would like to add 2 things to the list
11) it is NOT easy at all to swap a v8 of any kind into a v6 mustang, it can be done but pretty much requires a wrecked gt to do
12)the supercharger from thunderbird supercoupes will not fit easily onto a v6 mustang, it requires many MANY other engine components out of the t-bird
enjoy
