Forced Induction How About A Vortech V3-si Trim On A 94 Cobra?
I drove it for quite a while with no issues at all. I did have an intermittent stalling problem upon deceleration with the clutch pushed in, but I just opened up the throttle blade by adjusting the screw on the throttle body and that fixed it. How many miles are on your engine/trans?
It only has like 11k on the rebuild motor and trans... I say this cause I cant confirm it.. I can tell that the motor has been out recently and it does have aluminum x302 head. I can see the gaskets on the motor are "newer:".. I have "from wut im told." x302 heads, 1.7 roller rockers, e 303 cam, 3.55 gears, 30# injectors, 70mm TB with 75 mm maf calibrated for 30# injectors... bbk shorties with x pipe and tips, polished ported cobra intake and CAI in the fender.. I went to the track and my first ever pass .. """ EVER""" down a track was a 13.95.. the best with 245 45 17 street tires(converted 5 lug) was 13.701 with 2.2 60' and 106 Mph on street tires.
supposibly the trans is a tremec t5 WC hd Z spec
in my basement I have a SCT Big Air 2600 90mm MAF with 60#injectors and adaptors, anderson power pipe and walbro 405 fuel pump waiting to be installed on my 306 (by the way not sure its a 306 but its been wut im told)with a v3 si kit.
Yep, the car was tuned by Lidio in Chesterfield. It sounds like you have everything you need to get it going. Just make sure you call and see what his schedule is like; he was a few weeks out when I first called to check his time frame and availability.
