how do i know if my rotor is cracked?
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
its my stock rear rotor that might be cracked. ive been doing a lot of hard driving lately. Lime Creek for those in the Austin area, and i drive City Park rd hard every day on my way to class. anyway, the driver side rear rotor has two lines going from the hub (inside) all the way to the outside of the rotor. i'd snap a pic, but my digi is broken :notnice: is this harmful to continue driving?
tomustang said:
well it ain't a marker stain! you running the barake too hard?
i have been pretty hard on the brakes lately. i was just throwing around ideas, do you think i could have cranked the E-brake too hard one time? probably not, but i was just trying to think of other things.
I'd say you're probably ok to drive til you can get a new one (if indeed it is cracked,) but if it goes, don't be surprised if you have to step on the brakes extra hard to stop. :)
tomustang said:
it's in the rear so it won't affect braking much, i think the rear ratio is less than 40% power
contradicting youself again Tom. :rlaugh:
tomustang said:
excessive heat, they are stock rotors, just a matter of time
If it won't affect the braking they wouldn't be doing much, but then how could you run them too hard? :shrug:
Wow! I always though you knew a lot about cars 300bhp/ton... Guess not...
Just because the rear brakes are only 40% of the brake force does not mean that they cannot be pushed to the limit of the braking that they were designed for. Ever heard of a performance envelope? They were pushed to the limit of their PE and failed... :owned:
not at all, it was more to just wind Tom up, lol.
As for the brakes them selfs, well that would depend. Unless cracked rear disc's is common on Mustangs (never heard/read it before myself) I would think it very unlikley that it is cracked.
As cracking would be associated with rapid heating and cooling over a short period of time, cracks can appear but it is far more common in cross drilled disc's as the hole introduces a weak spot where the crack will form.
It would be quite likley that any marks on the disc are just that marks, either from the pads or just part of the metal.
If the disc's are getting on a abit and are well used then blueing, glazing and uneven wear are much more likely. If they are already in this condition then there may cause for them to crack.
If there appears to be nothing wrong with the operation of the brakes then I personally wouldn't worry too much. If you do replace them make sure you do the pads as well.
It might be worth lifting the wheel off of the hub and having a closer look at the disc, if it is indeed cracked then it should become obvious. If it is just a mark then try cleaning that area of the disc with a cloth and some vapour degreaser. You may be able to do this with out taking the wheel off the car, depending what style wheels you have.
He also fails to mention whether or not he was doing excessive burnouts (heavy rear brake use) or e-braking for fun. Those two can cause the entire stress of the braking effort to be pointed directly at the rear brakes.
i for one did NOT do that to my car .. and i have a crack in mine..
where to get some new ones ? not stock , something nice ?
i dont have the $$ to do burnouts, nor E-brake. i do drive hard and brake hard though
look on ebay and search for "mustang rotors". i found some nice Brembo drilled/slotted rear discs for $120
