I accidently broke one of the bolts that u use to install the throttle body,so now I need to replace it. But I don't know how. ? Help please Posted via Mobile Device
The studs go through the EGR spacer into the intake.
Unbolt the 4 nuts on the TB, take the TB off. Then either pry between the intake and EGR spacer gently or whack it with a rubber mallet to break the EGR spacer loose from the intake.
Then you'll need a pipe wrench or vice grips to spin out the studs.
