How do you remove the
woodsnake
1,352
15
69
Hicksville, NY
Pump cam, on a Holley mechanical secondary carb???:fuss:
There is an "E" Clip, it looks like it should be a stud, and yet I can't just pull it off, and the whole thing acts like it's threaded into the base plate. However, the cam arm won't have enough clearance to un-thread, even if you remove the throttle plate assy. W.T F!! :mad::bang:
In case anyone else runs into this problem, I ended up with the carb upside down in a vice, and used a 'hot wrench' to break the rust free. Took a few minutes between heat and leveraging, but it finally came off. Not nearly as easy as it should have!
