how does this setup sound?
  • Thread starter Thread starter wgpaintballer
  • Start date Start date Dec 25, 2005
W
wgpaintballer
49
  • Dec 25, 2005
Trickflow HCI kit
70 mm throttle body + egr should i go bigger?
mass air sensor
AEM cold air
Flowmaster American Thunder
T5 conversion
3.73 gears
shortthrow shifter
BBK shorty headers plus catted hpipe
down the road 347 stroker + nos
will the trickflow twisted wedge work with a 347 and my 302?
should i upgrade to msd i didnt hear great things about them
am i going to need a new fuel pump? also what injectors should i use
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 25, 2005
  • Dec 25, 2005
Sounds good, but......
Forget the AEM and use a stock airbox with a drop-in filter.
Forget the ignition box. its unnecessary uless you start pouring on the boost.
Yes, the TWs will work on a 347.
L
luckythirteen13
648
Anaheim, CA
Dec 25, 2005
  • Dec 25, 2005
you have to match the egr to the tb so if you go up to 70mm on the tb you will have to do the same with the egr.
the set up sounds good but i agree about the cai. they are worthless. just pull out the air silencer and put in a flat filter in the stock box. youll also want to upgrade the maf. with a 70mm tb id run 76-80mm maf
id get the msd box, coil and wires. all 3 together are supposed to add about 10hp and they make the car much more responsive
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 25, 2005
  • Dec 25, 2005
The tfs h/c/i kit will bolt right on to a 347 BUT you will need pistons that'll work with tfs heads. I suggest probe srs pistons.
Use a 75mm tb. Don't waste your money on an msd, its useless at your level like tits on a bull.
Use 30lb injectors and a 255 fuel pump.
I agree, don't waste any money on that "cold air kit".
I hope you're not gonna use a tfs street intake and a tfs stage 1 cam on a 347?? Thats WAY too small. It'll make a bit more under the curve power, but not much more up top over the 302. Maybe 315rwhp with that kit + shorty headers on a 347. I also hope you're not gonna use 1 5/8" shortys on a 347??
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Dec 25, 2005
  • Dec 25, 2005
get the msd.. it helps when done right lol
aleborjas
610
  • Dec 26, 2005
if you are getting TFS kit get TW kit, i think 70mm TB is ok for both engines and dont waste on CAI, the MSD is not needed get only a good coil, and get LT's hedders 1 5/8, 24's work for the 302 but for the 347 you need little more.
I
IntenseBlue
946
  • Dec 26, 2005
Sounds good to me. You can only benifit from the MSD also.
  • dan50
  • Jul 18, 2026
dan50
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
