89 stock motor with a b303 cam,motorsport lifters,push rods,crane 1.7 rockers,bbk ssi intake,70 mm tb,mass air flow and 24 injectors with a 255 pump,bbk headers and h pipe with flow 40 cat back any ideas about hp and quarter mile #s
Injectors and pump seem to be overkill right now. If your adding a good set of heads then you would need that size injectors.
Going to say 225-240 to the wheels. don't know about times. Missing info like whats trans, rear gear. But on a guess mid 13's also is a hatch,notch,vert all this stuff factors in
if your lucky,175 at the tires, dont take anybodys guess at your horsepower(even though im pretty close) go put it on a dyno! thats the only honest way to figure out what you have; everything else is just a guess
"Going to say 225-240 to the wheels. don't know about times. " yep.. this is a real life close est!! Heads and maybe advancing the cam will allow 290 310 at the wheels!!
Amazing that someone with such little knowledge is trying to pass on "information".
I had a nearly identical car, but with a Cobra intake. I make 221rwhp and 272tq. I would suspect that you've got anywhere from 210 - 230 at the wheels.
