i also would not mill the heads. 5cc is only .1-.2 worth of compression, so an engine that had 9.5:1 drops to 9.3:1. not enough to worry about since the added airflow and larger valves will vastly more than make up for any horsepower lost. but if you are set on milling the heads, then yes about .020 should get you where you want to be.
