how to adjust valves on 88GT
v8tiger
can anyone explain to me how to adjust my valves so they arent open all the time.
IE: making my car miss. Because the valve cant close from the rockers being too tight. But when i make them looser, they come loose and start to tick.
i have GT40X heads, E303 Cam, Cobra intake. With rockers that just bolt on, no set screw or ne thing.
If the idle increased when you sprayed the carb cleaner or TB cleaner around the gaskets, i.e. upper to lower, TB to EGR spacer, EGR spacer to upper then it sounds like you also have a vacuum leak. Go through and make sure that all the bolts are tight and to the proper torque specs.
