How To Compare Tires?
imp
Mustang Master
Jul 13, 2017
531
105
83
69
My '94 GT, bought recently, has optional 17" wheels, and surprised I was to see good quality rubber on them: 245/45/ ZR 17 by Goodyear, directional like on my '93 Cobra. They're about 10 to 20 % tread, though, evenly worn, no visible evidence of plugs, punctures, etc. But, they will have to go, soon.
I went lookin' for 245/45/ 17, regardless of speed rating. Price ranged from $78 to around $300!!
How does a guy go about buying tires given this kind of disparity? I had a set of "bullet-holes" rims years back, bought cheapie tires for the Cobra (money was TIGHT!), and we rode them for several years.
What process do you recommend I follow in buying tires for this '94 GT? Usage is as a 2nd. car, not daily, I'm too Goddamned old to race guys from stoplights, (but did it furiously) as a youngster, so, tires? I dunno....imp
Reactions: RaggedGT
  • Sponsors(?)
cbdallas
49
51
I shop by UTQG ratings on TireRack, then buy them at Discount Tire. My Camaro (2011 V6 RS) came with some extremely soft 21" tires on it (I think they lasted 8,000 miles of mild cruising), and they were REALLY expensive, so I replaced them with something with a higher treadwear number and have been completely satisfied. They're still going at 32,000 miles. I don't race, so I choose durability over ultimate grip.
Thread starter Similar threads Forum Replies Date
A 05-09 4.6 v8 engine comparability 2005 - 2014 S-197 Mustang -General/Talk- 0
H 1989 gt vortech supercharged microsquirt, having trouble getting idle set, need a tune to compare. Digital Self-tuning Forum 4
Gabe_02Ruby 99-04 Convertible Compared To Coupe (gt)? 1996 - 2004 SN95 Mustang -General/Talk- 10
Gabe_02Ruby 99-04 Gt Convertible Compared To The Coupe. The Welcome Wagon 4
90lxwhite For Anyone Wanting To Compare Head Flow Here's A Chart 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
805mustang Help!!! Need Var Cam Time Live Data Values To Compare With! 2005 - 2009 Specific Tech 0
from6to8 Help: Are these 2 parts comparable to use? Ball joints 1994 - 1995 Specific Tech 5
ximportdriver How Heavy is your '13? Comparing Base Weight to the Listed Weight in the Door Jam 2005 - 2014 S-197 Mustang -General/Talk- 2
'13_ImpactBlue_GT General G-max Compared To The Oe Pirelli's? 2010 - 2014 Specific Tech 1
Venom351R What Size Is A Mini Starter Compared To The Standard Length Starter? 1994 - 1995 Specific Tech 2
O radiator to block clearance question. 94 95 compared to a fox 1994 - 1995 Specific Tech 22
gikort How KH factory disc brakes compare to modern/aftermarket Classic Mustang Specific Tech 7
S Rebuilding a 4.6 compared to a 5.0 1996 - 2004 SN95 Mustang -General/Talk- 0
mtaqua size of 65/66 deck lid compared to 67/68 Classic Mustang Specific Tech 7
gxnos took almost 3 seconds off my ET, comparing time slips 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
R Comparing the 2011 Mustang V6 .... 2005 - 2014 S-197 Mustang -General/Talk- 10
T A Friend just got a GT500... how fast?? compare to Blown GT?? 2005 - 2009 Specific Tech 6
timeless2 Video: Consumer Reports compares Mustang Camaro Challenger 2010 - 2014 Specific Tech 5
timeless2 Video: Consumer Reports compares Mustang Camaro Challenger StangNet Site News 1
3 Comparing Stock 4V Heads SN95 4.6L Mustang Tech 1
94GTLaserRC Election...Let's See How SN Compares To Nation 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 87
Booksix My 89 T5 input shaft compared to 02 input shaft Fox 5.0 Mustang Tech 2
final5-0 NA 418, 347, 5.0, & Blown 5.0 Dyno Pull Compare-O 1994 - 1995 Specific Tech 19
DarkoStoj strength of the early 302 blocks compared to the 5.0 roller blocks Classic Mustang Specific Tech 16
D AFR and Trickflows: Dyno graphs & street fun.. lets compare shall we? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
M How is 50resto's Quality 87-93 foglight switch compared to OEM piece? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
M Lets compare the New 2005-2008 Stangs to the Fox stangs... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 44
Redeemedsoul 1987 gt compared to 1988/1989 Fox 5.0 Mustang Tech 13
jerry S how do these two cams compare? Classic Mustang Specific Tech 3
jhonda Just looked up a dyno graph compared to mine 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
L Sound quality compared to Mach 460? Mustang Sound & Shine All 2
D Comparing track times 1996 - 2004 SN95 Mustang -General/Talk- 8
S how do toyo proxes t1r's compare to bfg kdw2's? 1996 - 2004 SN95 Mustang -General/Talk- 6
H How does the 99-04's compare to the 05+ 1996 - 2004 SN95 Mustang -General/Talk- 6
gnx547 Weight of a fox body pony rim compared to a Weld Pro Star? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
The Green GT How do Nitto 315's compare to normal 315's? 1994 - 1995 Specific Tech 16
anthony05gt COMPARED: MGW vs. Steeda Triax 2005 - 2009 Specific Tech 20
Pokageek Again..How does a H/C/I 302 compare to a evo or sti? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 64
M 95 compared to 96 performance SVT Tech Forum 1
X Installed injectors - Gap when comparing both fuel rails? SN95 4.6L Mustang Tech 3
M 1972 Factory tach accuracy compared to aftermarket Classic Mustang Specific Tech 8
Pokageek Guys with 347ci..how's your low end/tq curve compared to a 302? 1994 - 1995 Specific Tech 12
K Comparing GT to Cobra SVT Tech Forum 10
billfisher how do you compare to an 07 SS impala? 2005 - 2014 S-197 Mustang -General/Talk- 12
0 How does an 02GT compare to a 350z? 1996 - 2004 SN95 Mustang -General/Talk- 32
S Compare the Granatelli c.o.p.'s with Accel's SN95 4.6L Mustang Tech 15
2 Compare front drop of Bullit Suspension kit to Ford C Springs. SN95 4.6L Mustang Tech 2
Dan95-5.0 mach460 head unit compared to standard head unit 1994 - 1995 Specific Tech 2
M How fast is new Mustang compare to Camaro LS1? 2005 - 2014 S-197 Mustang -General/Talk- 12
C How does a bolt-on 4.6 2V compare to a stock 350Z? 1996 - 2004 SN95 Mustang -General/Talk- 39
