How to put car on jackstands?
What are you planning on doing??? If your crawling under it I, personally, would want more than one jack in the middle of the car. The ONLY time i've ever done it the way you describe was to lift the engine up enough to undo the motor mounts. I don't think you'd want to lift the car off the ground by the oil pan.
If you put a jackstand under the subframe on each side of the car it will work. This is what I do (and i'm sure many others) when i'm changing the oil, etc.
If you really want to put the jackstands elsewhere, jack it up from the subframes and then put a jackstand under the K member on both sides just inwards of the control arms. Use common sense, if it doesn't looks strong enough to hold the weight of the car it probably isn't.
You want to put it on jack stands and remove the wheels for winter? Not a bad decision.
Thanks guys, i just jacked it up on the sub frame, one corner at a time. I wasn't sure whether it was healthy for the frame of the car to do that, but i guess its fine.
It was a tight fit, but it's better than leaving it in the snow!
I raise mine in the front uner the K-member do I can do both front jackstands at the same time - under the lower A-arm. I then raise the rear by the pumpkin and place the jack stands at the outer ends of the axles. This supports the car just like it was standing on the ground. I do it for servicing during the winter and I'd do it if I wasn't servicing it to keep the tires from taking a temporary set (flat spot).
yeha i do it by the rails on either side in the front and put the stands under there....and the back i jack it just inside the torque box next to the muffler, there is a little rail tehre too..but i will start doing it by the rear end next time.
TMOSS, thats what i was looking for!
I saw a pic of someone jacking their car up by the front, in the middle.. for some reason i thought they had it under the oil pan, but it must have been the K-member.
About the location of jack stands, im storing the car for about 6 months, and i have all jack stands under the sub frame with the suspension unloaded. Is this OK or should i set it up like TMOSS with the suspension set as it would be sitting on the ground?
I would suggest cleaning your car before you store it :nice:
I put the jack under the front k-member, and then the two jack stands on the k-member, and then two more jackstands on the end of the axles, and use the jack on the pumpkin to lift it up, basically juse like TMOSS :flag:
