I find it hard to believe you bent a valve at 5900...You sure it wasn't higher?
I'd go with swapping the spark plug 1st. Can't hurt.
svttech76 said:the spark plug could have been crushed from violent detonation. try putting another plug in before you pull the head.
or just go ahead and not even try the plug ( it would take a few minutes) and maybe waste thousands.
. And im not against S/C, my 66 should have an intercooled novi 2000 on it by the end of this year or so
. We are going to have to build our own IC out of an open core you can buy in about any size....so that should be fun lol.
hotmustang331 said:Well carbon buildup increases compression.
Possable cenario (sp) ....you went WOT, the carbon buildup got to the point where it caused detination. the detination was minimal, but bent the plug...and also blew off a chunk of carbon when that happened that got cought in the valve on its way out (or possably on the inatke). Thus your problem.
I have seen some CRAZY stuff happen, and the above is VERY possasable lol. Hope it all works out as inexpencively as possable.
BUT I stand confedent that it wasnt caused by valve float.
Anyways see thats exactly why i dont want a S/C...this crap happens and your VERY lucky you engine didnt let go.
if it was just the plug. svttech76 said:that is very possible to, In fact that happens a lot to the DOHC 3.0 taurus![]()
but I was saying start small then go to the big stuff because you will feelif it was just the plug.
but after what I just read about him looking for a excuss to add power. this guy wants t get them heads off![]()
. How did i get off on that
.IBChillin32182 said:I have looked at chp, livernois and dss. Are there any other companies I should consider?
