I am having a problem with datalogging
rj95svt
422
Hayden, AL
I tried to do a datalog lastnight and I noticed if I go to utilities and click on the recomended things to datalog for CBAZA and do a datalog everything works fine but if I go down the list and click the things I want to datalog specifically it doesn't work right.
Example: one of the things that happened the rpm's was showing 2800 yet the car was idling normally at around 700 rpms. This is just one example there were other things like that happening as well.
Am I doing something wrong or is there a glitch in the software? If there is a glitch how can I fix the problem?
You need to rewrite the Tweecer each time you change the payloads, also check that if you are using the Calcon/Caledit the option "Update Only" is not active and you rewrite the whole tune.
