- Jul 8, 2005
- 114
- 0
- 0
I just purchased a 93 lx coupe today. My question reguards the tachometer, it reads irratically, and typically thousands of rpms lower than it's actually pumping. This car is coil pack dual plug. Any one used to this problem?
Distortion 5.0 said:Hey guys, that's not the DIS module is it? I changed the DIS today and it made no difference what so ever. Where is this ICM of which you speak located? Anyone?
Thank you stinger, I knew when I saw that you posted my question was answered. It was a j/y part that I traded a hashed lx for.Stinger said:If you changed it and it didn't help, your new one is no good...the ignition module is the only thing that effects the tach readout.
TMX said:There really isn't gears for the tach readings. The ECU figures out when a coil fires and how often it fires from the output of the ICM which controls the coil firing and selection. It's very easy to find out how many revolutions the engine makes by the coil spark. With the distributor systems, there might have been gears to control it, but in the DIS system when everything is electronically controlled, it all becomes just calculations.
Definitely in 92 and 93. I started with a 92 that I bought new in 91.TMX said:I believe in 1989, but that could be off. Definately sure in 1993 it was DIS, and I believe 1992 was as well.
