Well yesterday I was going to get my exhaust welded up and my girls dads shop. I drive up there with no problems, the car made no noise or got hot or anything. On the way back I'm sitting at the light, and I'm thinking I here the rockers ticking, but I'm like "nah can't be". So I pull into Wendys and I shut it off. I come back out and it's kinda hard to start. I drive home and the motor runs perfect. I left the car running and opend the hood and then I here the rockers screaming and it was burning hot! I checked the water, water pump ect, but it's all good. I then pulled off the drivers side valve cover, turned the motor over and no oil to the rockers! I then pulled the dist and checked the oil pump rod, in perfect shape. then I pulled the pan and checked the pump and the pickup. The pump is a high volume. Well the problem was the pick up, the previous owner used blue silicon to put the pan up and ALOT of it peeled off and got into the oil and cloged up the pick up.
All this could have been avoided if my lazy A$$ would have hooked up the oil sending unit and the temp gauge when I swaped the motor
. When I drained the oil I was expecting a river of flakes and chips, but NOT A SINGLE ONE! So I figured, "there all in the bottom of the oil pan", when I pulled the pan no chips of flakes either! I drove the car at least 7 miles or so, so I would have put money on it that I destoryed the bearings ???
