I need help, please read.
  • Thread starter Thread starter notsoswwuyd
  • Start date Start date Apr 7, 2005
N
notsoswwuyd
21
Wichita Falls Texas
Apr 7, 2005
  • Apr 7, 2005
Hello all, I have an 89 gt vert. I bought a trick flow stage one cam, and a 76mm c&l maf with 24# injectors, installed it all and now the car will not hardly idle if I come to a fast stop, it will reve up two or three times and die. I reset my tps to .95 at idle and reset my idle. Please help. Thanks for all of your time.
stang22
1,318
Washington, D.C.
Apr 7, 2005
  • Apr 7, 2005
What's your fuel pressure at?
Did you pull any codes?
Do you have the right calibration tube for those injectors?
Any vacuum leaks?
Tim
N
notsoswwuyd
21
Wichita Falls Texas
Apr 7, 2005
  • Apr 7, 2005
man your car looks bad ass!!
yes the calibration tube is the correct one.
I have not checked my fuel pressure, but I will shortly, what should it be with the stock regulator?
I have checked for vac leaks, and not found any but I will check again.
my ses light is not on, could there still be codes?
I was thinking that it might be my tb is too small?
04sleeper
2,674
14
89
Dallas, TX
Apr 7, 2005
  • Apr 7, 2005
I don't think the TB being too small that is causing your issue.
Have you tried "clocking" the mass air? I have heard this sometimes helps with C/L's.
dstanggt50
1,316
Woodinville, WA
Apr 7, 2005
  • Apr 7, 2005
the only time I've heard of clocking the meter is if there is a cold air on the car, if you have one, I would try that, but I would assume that the idle issue is w/either the fuel pressure, vacuum leaks, maybe timing??? If you are using the 76maf w/the stock airbox or the kit that it comes with usiing the heat shield , I would assume you should be ok. I have the 76maf kit, didn't have to clock mine, idles ok considering my junk 94-95 processor w/the cam.
N
notsoswwuyd
21
Wichita Falls Texas
Apr 7, 2005
  • Apr 7, 2005
dstanggt50, my timming is set at 13*, do you know what the fuel pressure should be? And how much vacume should I be pulling at an idle, also does it matter where I tie my gauge in the check the vac? thanks for your time!!
dstanggt50
1,316
Woodinville, WA
Apr 7, 2005
  • Apr 7, 2005
I have my fuel pressure set at 44psi, but I think every car is different, i've heard some people run around 42 or so, not sure. Its been a while since I've checked my vacuum, but we used to run it off a vacuum hose that came off the intake. As far as how much vacuum, I guess I had an idiot guage cause it was color coded, I just went off of that , don't remember the exact #, If I had to guess I would say you want to have more than 12-14 , sorry, mine was color coded. Also, when I had my lunati cam in my old 87gt, I could not get my car idle at all, so we put an idle spacer( don't know if that is the correct name), it looked like a spacer that went on the iac, and had a screw you could adjust. It was the only way I could get that car to idle, may wanna look into that if everything else checks out. Might also want to check codes as well.
W
white88
Frisco,TX
Apr 7, 2005
  • Apr 7, 2005
I had a similar problem in my LX after cam and intake install. My car wouldn't idle it surged and sounded crappy. It ended up being a huge vacuum leak, on of the lower intake gaskets was faulty. Now my car runs awesome, better than it ever has. I hope this helps.
N
notsoswwuyd
21
Wichita Falls Texas
Apr 7, 2005
  • Apr 7, 2005
where did you get the idle spacer? thanks for your time.
dstanggt50
1,316
Woodinville, WA
Apr 8, 2005
#10
  • Apr 8, 2005
  • #10
Dallas Mustangs
1-800-mustang
C
Convertible help needed Please
  • Curtis Harper
  • Apr 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 26, 2026
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
